gramx Posted January 29, 2020 Share Posted January 29, 2020 Hi, Loving the speed of the new sparse solver in Houdini 18. I have a job where I have a medium res simulation and I need to upres it for final render without the motion changing to much. I would usually use the Up-Res shelf tool to set this up, but have found it doesn't accept the sparse solver as a source. Is it possible to manually set these up, has anyone tried it? Thanks Graham Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted January 29, 2020 Share Posted January 29, 2020 4 hours ago, gramx said: Hi, Loving the speed of the new sparse solver in Houdini 18. I have a job where I have a medium res simulation and I need to upres it for final render without the motion changing to much. I would usually use the Up-Res shelf tool to set this up, but have found it doesn't accept the sparse solver as a source. Is it possible to manually set these up, has anyone tried it? Thanks Graham Hey Graham! I think is all about to update the up-rez pipeline to make it sparse. I think is not that hard to do it! Cheers! Alejandro Quote Link to comment Share on other sites More sharing options...
sekow Posted January 29, 2020 Share Posted January 29, 2020 just did this today.. cached out vel and piped it back into a dop net with upres solver. but build it up from scratch Quote Link to comment Share on other sites More sharing options...
gramx Posted January 30, 2020 Author Share Posted January 30, 2020 (edited) Thanks for the replies, good to know that it can be hooked in to the regular upres solver. I will give it a go. Edited January 30, 2020 by gramx Quote Link to comment Share on other sites More sharing options...
bunker Posted February 2, 2020 Share Posted February 2, 2020 you can also duplicate your DOPnet and disable everything related to vel since you copy it from the loweres sim eg: forces/buoyancy/vel advection/projection then just copy "compute turb","ramp turbscale","primary noise" from the gasUpres solver and you get a sparse upres. https://vimeo.com/388758247 5 Quote Link to comment Share on other sites More sharing options...
gramx Posted February 3, 2020 Author Share Posted February 3, 2020 On 02/02/2020 at 1:57 AM, bunker said: you can also duplicate your DOPnet and disable everything related to vel since you copy it from the loweres sim eg: forces/buoyancy/vel advection/projection then just copy "compute turb","ramp turbscale","primary noise" from the gasUpres solver and you get a sparse upres. https://vimeo.com/388758247 Thanks for the tip Quote Link to comment Share on other sites More sharing options...
Sifis Posted February 16, 2020 Share Posted February 16, 2020 On 2/2/2020 at 3:57 AM, bunker said: you can also duplicate your DOPnet and disable everything related to vel since you copy it from the loweres sim eg: forces/buoyancy/vel advection/projection then just copy "compute turb","ramp turbscale","primary noise" from the gasUpres solver and you get a sparse upres. https://vimeo.com/388758247 Thank you Bunker, A simple hip would be great if it's possible. Quote Link to comment Share on other sites More sharing options...
bunker Posted February 24, 2020 Share Posted February 24, 2020 @iosif I'm making a small tutorial about it now, a hip file wouldn't explain much, there are quite a few steps... 5 Quote Link to comment Share on other sites More sharing options...
Popular Post bunker Posted March 2, 2020 Popular Post Share Posted March 2, 2020 (edited) Here is my tutorial, done super fast so don't be too harsh I hope this is helpful Sparse Pyro Upres, the easy way - part1 Edited March 2, 2020 by bunker 9 5 Quote Link to comment Share on other sites More sharing options...
gramx Posted March 2, 2020 Author Share Posted March 2, 2020 3 hours ago, bunker said: Here is my tutorial, done super fast so don't be too harsh I hope this is helpful Sparse Pyro Upres, the easy way - part1 Thanks for going to the trouble of making a tutorial, it's really useful Quote Link to comment Share on other sites More sharing options...
k2p8 Posted May 7, 2020 Share Posted May 7, 2020 Hi folks ! I am working on a sparse pyro upres on my 'sparse' time (lol). I tryed to automate as much as possible the process by normalizing inputs and coding a python script that copy and paste all the params of the lowres simulation to the upres node. So the only thing to work with after matching params from the script is the noise / dissipation of the upres. I added a hip with hda in the link. The hip is annoted to guide you through the process. https://drive.google.com/drive/folders/1H4Y0HNELDJ6lmHsM43eEI_lRgNuCEaxX?usp=sharing the pipeline is fairly simple : 1. add a configure input node, it will merge all inputs from low res sim and source to normalize and rename fields 2. add the sparse pyro upres node 3. In the tab match properties of the upres node drag the lowres pyro and click match properties 4. enjoy The sparse solver itself is a deeply modified sparse pyro where you basicly cancel all nodes relatives to vel advection / projection and import the vel from the lowres in copy mode. Then you can add your sources (without the vel or v sourcing since it has already been calculated in the lowres) and add some noise. Since vel is in copy your noise won't last in the sim so i created a noise channel in the smoke object that is advected by the vel and merge to the vel. You can also simulate your low res without color and add color to your upres source and simulate an upres with color, it only needs a Cd and Alpha channel. 5 Quote Link to comment Share on other sites More sharing options...
gramx Posted May 11, 2020 Author Share Posted May 11, 2020 On 07/05/2020 at 6:18 PM, k2p8 said: Hi folks ! I am working on a sparse pyro upres on my 'sparse' time (lol). I tryed to automate as much as possible the process by normalizing inputs and coding a python script that copy and paste all the params of the lowres simulation to the upres node. So the only thing to work with after matching params from the script is the noise / dissipation of the upres. I added a hip with hda in the link. The hip is annoted to guide you through the process. https://drive.google.com/drive/folders/1H4Y0HNELDJ6lmHsM43eEI_lRgNuCEaxX?usp=sharing the pipeline is fairly simple : 1. add a configure input node, it will merge all inputs from low res sim and source to normalize and rename fields 2. add the sparse pyro upres node 3. In the tab match properties of the upres node drag the lowres pyro and click match properties 4. enjoy The sparse solver itself is a deeply modified sparse pyro where you basicly cancel all nodes relatives to vel advection / projection and import the vel from the lowres in copy mode. Then you can add your sources (without the vel or v sourcing since it has already been calculated in the lowres) and add some noise. Since vel is in copy your noise won't last in the sim so i created a noise channel in the smoke object that is advected by the vel and merge to the vel. You can also simulate your low res without color and add color to your upres source and simulate an upres with color, it only needs a Cd and Alpha channel. Thanks for sharing this Quote Link to comment Share on other sites More sharing options...
k2p8 Posted June 2, 2020 Share Posted June 2, 2020 On 11/05/2020 at 11:18 AM, gramx said: Thanks for sharing this You're welcome I updated a bit the solver and did a video to test it here is the link with the updated solver (it's the same as the previous one) https://drive.google.com/drive/folders/1H4Y0HNELDJ6lmHsM43eEI_lRgNuCEaxX?usp=sharing 2 1 Quote Link to comment Share on other sites More sharing options...
gramx Posted June 3, 2020 Author Share Posted June 3, 2020 21 hours ago, k2p8 said: You're welcome I updated a bit the solver and did a video to test it here is the link with the updated solver (it's the same as the previous one) https://drive.google.com/drive/folders/1H4Y0HNELDJ6lmHsM43eEI_lRgNuCEaxX?usp=sharing Thanks for sharing this, looks great! Super fast details 3 Quote Link to comment Share on other sites More sharing options...
eunchae Posted November 7, 2020 Share Posted November 7, 2020 Hello. @k2p8 This is a basic question... I'm not sure what upres do. Does it change low resolution to high resolution? If anyone knows, let me know. Thanks if you let me know. Quote Link to comment Share on other sites More sharing options...
eunchae Posted November 7, 2020 Share Posted November 7, 2020 On 2020. 3. 2. at 3:16 PM, bunker said: Here is my tutorial, done super fast so don't be too harsh I hope this is helpful Sparse Pyro Upres, the easy way - part1 Thanks for sharing. Is it part2 too? Quote Link to comment Share on other sites More sharing options...
k2p8 Posted November 8, 2020 Share Posted November 8, 2020 Hi @eunchae, The basic principle of an upres is to make a new simulation with a pre-existing velocity grid that you use to drive a new dye (density / temperature). Your new simulation should have smaller voxels and parameters close to the lowres (like temperature diffusion, flame amount, time step) if you want this new version to be close to the lowres. You then copy the lowres velocity and simply advect the upres by it. This way you only perform heavy computation like divergent free velocity (ensure the conservation of the mass of the fluid) and the boundary collision on the lowres, the upres solver only has an advect for the density / temperature / ect. all other nodes relative to velocity enforcement / computation are deseabled which allow you to quiclky compute the upres and skip all the heavy parts. Then you can add a little amount of noise with an add operation to the copyed lowres velocity to give more details to your upres. This small amount is almost divergent free on a large scale so it should not be a problem. You can add any forces at this process in the upres, but, the divergent free velocity node being desabled, only already divergent free forces should be added. Otherwise your smoke will compress into itself. And you should only add forces that do not push your upres smoke to far from the lowres, since you simply copy the lowres velocity, no new velocity will be computed outside of this bounds. So, for example, adding a wind, which is divergent free, is not a good option since your smoke will crash into the bounds of the lowres. There is some parameters that do not scale well with the upres, usually it is all parameters or operations that need neighbours voxels to be performed, like temperature diffusion. Since you change the size of the voxels, those operations have an overall result which is generaly not the same as the lowres. You could correct that by sampling the lowres version of the simulation and modify the output value, but you lose a lot of details by doing so. So in this case, it is better to slightly twik the upres simulation to perform better, by increasing or reducing the corresponding parameters. 1 Quote Link to comment Share on other sites More sharing options...
eunchae Posted November 10, 2020 Share Posted November 10, 2020 On 2020. 11. 9. at 2:49 AM, k2p8 said: Hi @eunchae, The basic principle of an upres is to make a new simulation with a pre-existing velocity grid that you use to drive a new dye (density / temperature). Your new simulation should have smaller voxels and parameters close to the lowres (like temperature diffusion, flame amount, time step) if you want this new version to be close to the lowres. You then copy the lowres velocity and simply advect the upres by it. This way you only perform heavy computation like divergent free velocity (ensure the conservation of the mass of the fluid) and the boundary collision on the lowres, the upres solver only has an advect for the density / temperature / ect. all other nodes relative to velocity enforcement / computation are deseabled which allow you to quiclky compute the upres and skip all the heavy parts. Then you can add a little amount of noise with an add operation to the copyed lowres velocity to give more details to your upres. This small amount is almost divergent free on a large scale so it should not be a problem. You can add any forces at this process in the upres, but, the divergent free velocity node being desabled, only already divergent free forces should be added. Otherwise your smoke will compress into itself. And you should only add forces that do not push your upres smoke to far from the lowres, since you simply copy the lowres velocity, no new velocity will be computed outside of this bounds. So, for example, adding a wind, which is divergent free, is not a good option since your smoke will crash into the bounds of the lowres. There is some parameters that do not scale well with the upres, usually it is all parameters or operations that need neighbours voxels to be performed, like temperature diffusion. Since you change the size of the voxels, those operations have an overall result which is generaly not the same as the lowres. You could correct that by sampling the lowres version of the simulation and modify the output value, but you lose a lot of details by doing so. So in this case, it is better to slightly twik the upres simulation to perform better, by increasing or reducing the corresponding parameters. Oh my god... I was impressed with your kindness. It has helped me a lot. Thank you very much!! Quote Link to comment Share on other sites More sharing options...
bunker Posted November 10, 2020 Share Posted November 10, 2020 On 2020-11-07 at 3:58 AM, eunchae said: Thanks for sharing. Is it part2 too? I've been a bit too busy to work on Part2 just yet, but feel free to ask questions here. 3 1 Quote Link to comment Share on other sites More sharing options...
gangland Posted April 25, 2022 Share Posted April 25, 2022 Hi Guys! I trying to implement those uprez solutions in my setup but i not getting an good result at all. i followed the tutorial by @bunker, i haveing issues with colision, it seems that the uprez fire is overlaping the collider. also the flames are getting crazy like going far from the low res bounds Quote Link to comment Share on other sites More sharing options...
