Scatter Points in Volume
it's because your resulting VDB from VDB Analysis SOP is a vector volume, Scatter SOP works only on float volumes
you can use VDB Vector Split to split it into 3 float volumes then either use Scatter SOP on all 3 or first delete 1 or 2 of those if you just want to use a single component for scattering
  • Thanks 1
