Pin Attach Constraint RBD object
RomanoWina
I am looking for a way to make the top of cup/Bucket interact/collide with a fluid mesh so that the fluid will lift the lid of the cup when it comes out without sending it in the air, it will remain attached on the x axis.
i was thinking of using a RBD Pin Constraint  (but it doesn't work) or using a bone on a static object using the deforming geo so the top will rotate only on the Z axis. What would be best?
Thanks for your advices,
Romano
Bucket.hipnc
I would use a hard constraint with type set to ''position'' for the hinge.
For simple one-way collision with the fluid I'd mesh the fluid, convert that to vdb and get a collider for bullet with vdbtospheres.
eg. like in the attached file
it would probably be a good idea to match the flip solver substeps to the bullet substeps.
constd.hipncFetching info...
Edited by nuki
  • 7 months later...
