ela1995 Posted March 3, 2020 Share Posted March 3, 2020 Hi, Recently I have trouble when using the Volume Source as a Collision for my pyro scene. I cache out the object in VDB, then loaded back into a new scene. Why my smoke still don't collide with the collision? Quote Link to comment Share on other sites More sharing options...
Diego A Grimaldi Posted March 4, 2020 Share Posted March 4, 2020 is the name on the field correct? Did you check the gradient of the volume? Quote Link to comment Share on other sites More sharing options...
ela1995 Posted April 13, 2020 Author Share Posted April 13, 2020 On 3/4/2020 at 11:35 PM, Diego A Grimaldi said: is the name on the field correct? Did you check the gradient of the volume? Expand I believe 'collision' and 'v' is the require field in order to create the collision using volumeSource. I'm sure the name on the field is correct, but what is the gradient of the volume? Quote Link to comment Share on other sites More sharing options...
ronit1996 Posted April 15, 2020 Share Posted April 15, 2020 On 4/13/2020 at 9:21 AM, ela1995 said: I believe 'collision' and 'v' is the require field in order to create the collision using volumeSource. I'm sure the name on the field is correct, but what is the gradient of the volume? Expand make sure that your v is going into the sim by the name collisionvel and the gradient is the value that vdbs have in them you need to put the value of collision as -1 in the volumesource node Quote Link to comment Share on other sites More sharing options...
