CinnamonMetal Posted March 10, 2020 Share Posted March 10, 2020 The particles are deforming along a curve, although once the particles reach a specific point on the curve, the particles stream single points; rather then a cluster of points, or rather; what is seen from the emitting base of the particles. How can I eliminate this single stream of points ? Quote Link to comment Share on other sites More sharing options...
Masoud Posted March 10, 2020 Share Posted March 10, 2020 Hi Christopher, Do you mean you need to emit particles along a path, same as what you have as emitter shape? Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 10, 2020 Author Share Posted March 10, 2020 The particles are emitting along a curve, although it may not be noticeable in the capture. The issue is; the particles are emitting how I want them too at the base of where the particles are emitting, but when the particles continue to follow the curve as seen in the capture the particles become a single point stream. I want what is at the base of the particles as seen in the capture to control where it is wide and thin; rather then a single stream of particles. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 12, 2020 Author Share Posted March 12, 2020 I've solved the problem 1 Quote Link to comment Share on other sites More sharing options...
Roznick Posted March 13, 2020 Share Posted March 13, 2020 12 hours ago, CinnamonMetal said: I've solved the problem Would you mind explaining how you solved it? Thanks 1 Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 15, 2020 Author Share Posted March 15, 2020 I added a spline curve to the vop network which has prevented the single stream of points Quote Link to comment Share on other sites More sharing options...
