For-each Patterns (Solved)
Found on some Asian--Forum only Picture and code.
I follow tutos and made (something:blush:)
but I have only H 16.5 and Qlib ( Don't get it- Centroid and for-each(extract -Centroid:blink: ) if someone can look  the file  and explain :wub:
prim_scale
vector max_pos=getbbox_max(1);
vector min_pos=getbbox_min(1);
float position=fit(@P.z,min_pos.x,max_pos.x,0,1);
float scale=chramp("scale",position)+0.5;
f@prim_scale=scale;
prim_color
float position=fit(@prim_scale,0.5,1.5,0,1);
vector color=chramp("prim_color",position);
@Cd=color;
TutosOdforce.hipnc
'Extract Centroid' can store the centroid as a primitive attribute. You can get the same effect by using centroid(0, *X/Y/Z*) in 'transform3''s pivot, then scale by 'prim_scale'. Not sure how the setup makes sense but maybe I'm missing something.
  • Librarian changed the title to For-each Patterns (Solved)
