madebygeoff Posted April 11, 2020 Share Posted April 11, 2020 I'm trying to create a vellum string setup where at a given frame, the string ignores one collision object, but not the others in a scene. I got something working with Vellum in DOPs and just switching up the static objects at a given frame. But it seems like there should be a more elegant way of doing it with collisionignore. I can get collisionignore to work as an initial point attribute, but I can't figure out how to alter the value at a given frame. Am I missing something simple and dumb? Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 11, 2020 Share Posted April 11, 2020 wanna upload your file ? just save me from mocking up something that might or might not match your problem, is all. Quote Link to comment Share on other sites More sharing options...
madebygeoff Posted April 11, 2020 Author Share Posted April 11, 2020 Sure. Thanks collision_release_v01.hiplc Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 11, 2020 Share Posted April 11, 2020 (edited) you're confusing me with the ignore section on the string...I thought we were talking about ignoring different colliders...just as well I asked for your file, hey !! anyway, here's my simple test, the diff colliders are named t1 t2 for ease of access (by default say you got just 1 tube, in your DOP you'd notice it is named external, so you could ignore by this name). Hence you see why I renamed my 2 tubes to t1 t2. You'll notice I've unlocked my vellumsolver to allow me to dive into the dopnet and modified the colliders naming, then once you've setup naming, go into forces up top, you'll see where i referenced t1 t2 to ignore at certain frames. hope that makes sense ps: from the gif, you can see CLEARLY the collliders are there in the sim, they just get ignored on command. vu_ignoreColliders.hiplc Edited April 11, 2020 by Noobini 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 12, 2020 Share Posted April 12, 2020 (edited) ps: you can even delete the merge (in SOP land) and have NO connection to the collision slot in vellumsolver...magically they still work since I'm referring to them in their SOP path now rather than opinput Edited April 12, 2020 by Noobini Quote Link to comment Share on other sites More sharing options...
anim Posted April 12, 2020 Share Posted April 12, 2020 (edited) you just need to animate @disbleexternal on the collider itself in SOPs here is your modified file with just one node added (Green) also I added Vellum Solver SOP (no need to unlock) in case you made DOP one just to try to solve this collision_release_v01_fix.hiplc Edited April 12, 2020 by anim 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 12, 2020 Share Posted April 12, 2020 37 minutes ago, anim said: you just need to animate @disbleexternal on the collider itself in SOPs here is your modified file with just one node added (Green) also I added Vellum Solver SOP (no need to unlock) in case you made DOP one just to try to solve this collision_release_v01_fix.hiplc ok, this approach just needs separate (point) groups to cater for multi tubes (or sections of one tube i guess) so you can disable whatever groups Quote Link to comment Share on other sites More sharing options...
anim Posted April 12, 2020 Share Posted April 12, 2020 yes, it's just based on the attribute per point so whether you use groups or not it's about the @disableexternal attribute but then further to define actual collision pairs it's possible to use s@collisionignore and s@collisiongroup attributes, but that's not necessary in this case Quote Link to comment Share on other sites More sharing options...
madebygeoff Posted April 12, 2020 Author Share Posted April 12, 2020 Thank you guys, I see the problem. When I tried before I was adding @collisionignore or @disableexternal to the vellum geo not the collision geo. In retrospect, I guess that seems obvious. For future problems, how did you know it was an attribute on the collision geo? When I looked at the Vellum Attributes page it was listed under Sim Attributes: Geo but it doesn't specify which attributes are Vellum geo attributes and which are collision geo attributes. Quote Link to comment Share on other sites More sharing options...
anim Posted April 12, 2020 Share Posted April 12, 2020 30 minutes ago, madebygeoff said: In retrospect, I guess that seems obvious. For future problems, how did you know it was an attribute on the collision geo? I simply tried it once cause I was desperately looking for solution and it worked so I remember (for now), obviously nowadays there is much more flexibility with collisiongroups, but sometimes you just want to disable particular collider completely Quote Link to comment Share on other sites More sharing options...
ProceduralFrankie Posted June 21, 2020 Share Posted June 21, 2020 Hey Guys! maybe not too late to ask, but how would you approach allowing one of the strings to collide with one tube, and the other with the other tube only ? So Line A wibt tube A only, and Line B with tube B only? See attached selective_collision_release_Fra.hiplc Quote Link to comment Share on other sites More sharing options...
madebygeoff Posted June 21, 2020 Author Share Posted June 21, 2020 (edited) As Tomas was pointing out above, you can use s@collisiongroup to set a point group name for each collision object (I used "tubeA" and "tubeB"). Then on each string set s@collisionignore to ignore the appropriate group. So string A s@collisionignore = "tubeB" and string B s@collisionignore = "tubeA". Here we're ignoring the entire object, but obviously since it's a point group, you can also select a subset of points on a collision object to ignore. selective_collision_release_mbG.hiplc Edited June 21, 2020 by madebygeoff 1 Quote Link to comment Share on other sites More sharing options...
ProceduralFrankie Posted June 25, 2020 Share Posted June 25, 2020 hey Geoff! Sorry but got extremely busy. That's sweet , thanks! Quote Link to comment Share on other sites More sharing options...
