davidyannick Posted April 13, 2020 Share Posted April 13, 2020 I'm trying to model a tower, but what is the best way to model a cross pattern for the supports ? Thanks for your help hdni_tower.hiplc Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted April 13, 2020 Share Posted April 13, 2020 Set a box to alternating triangles to get diagonals or extrude each polygon inwards and fuse to get crossings. crossing.hipnc Quote Link to comment Share on other sites More sharing options...
davidyannick Posted April 13, 2020 Author Share Posted April 13, 2020 1 minute ago, konstantin magnus said: Set a box to alternating triangles to get diagonals or extrude each polygon inwards and fuse to get crossings. crossing.hipnc thanks but in fact I'd like to have the crosses separated from the vertical support, I've tried this, but cross are merged with vertical support and Id' like to have crosses not on first and last point Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted April 13, 2020 Share Posted April 13, 2020 (edited) The new sweep gives you a lot of control over structures circling around curves. But you better get some reference in first and define all features before you start. Otherwise you might end up like a traditional modeler adding piece by piece leaving you with a very inflexible system. tower.hipnc Edited April 13, 2020 by konstantin magnus Quote Link to comment Share on other sites More sharing options...
davidyannick Posted April 13, 2020 Author Share Posted April 13, 2020 37 minutes ago, konstantin magnus said: The new sweep gives you a lot of control over structures circling around curves. But you better get some reference in first and define all features before you start. Otherwise you might end up like a traditional modeler adding piece by piece leaving you with a very inflexible system. tower.hipnc ok thanks again for your help Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 13, 2020 Share Posted April 13, 2020 behold: vu_hdni_tower.hipnc 2 Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 13, 2020 Share Posted April 13, 2020 (edited) does it have to be uniform ?......Feeeeeeeeck no... use a bend and taper it to the Eiffel Tower....will still work (well...sorta, as the flared bottom will have gaps....but that's enuff from me...you fill in the gaps) Edited April 13, 2020 by Noobini 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 13, 2020 Share Posted April 13, 2020 it should still work if your tower footprint is rectangular rather than square...and varying floor heights should work too i think. The Eiffel Tower structure is a bit puzzling...it still fits fine in front/back view...but side views, there's skewiff scaling Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 13, 2020 Share Posted April 13, 2020 FaultyTower with silly footprint and heights 1 Quote Link to comment Share on other sites More sharing options...
davidyannick Posted April 13, 2020 Author Share Posted April 13, 2020 8 minutes ago, Noobini said: FaultyTower with silly footprint and heights Excellent !!! Will you share it ? Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 13, 2020 Share Posted April 13, 2020 thought I'd leave it to ppl to experiment...it's the same file, I simply created a custom curve coz the orig solution works independent of footprint shape/height vu_hdni_tower2.hipnc 1 Quote Link to comment Share on other sites More sharing options...
davidyannick Posted April 13, 2020 Author Share Posted April 13, 2020 5 minutes ago, Noobini said: thought I'd leave it to ppl to experiment...it's the same file, I simply created a custom curve coz the orig solution works independent of footprint shape/height vu_hdni_tower2.hipnc thanks Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 13, 2020 Share Posted April 13, 2020 after the skin, you can select some panels with a group, call them holes, blast the holes and voila there are no crossbars at the holes ! Quote Link to comment Share on other sites More sharing options...
