random transform with for each loop
  • 1 year later...
rand(0.5234 + detail("../foreach_begin1_metadata1","iteration",0))
How do you set the values it produce inbetween two values. Let's say between -40 & 40
With this "For-Each connected Piece" all the objects get the same rotation/translate values, I tried to fix it but still no luck.
I spent hours trying to figure it out!
Thx
Edited by klawchi
The rand() function produces a value between 0-1. Knowing this, to set a range, simply use:
[range_start] + rand([seed]) * [range]
In your example, this would be:
-40 + rand(seed) * 80
Make sure your For Loop is running over the correct geometry type (Points/Prims/Count).
Thank you so much.
