Animated Texture Redshift
Hi all,
I'm very new into Houdini, but I'm loving it.
There are certain things that they must be quite simple to do but I'm not finding the way. This is importing a png sequence to use into the diffuse channel of a Redshift material.
If anybody can help it'd be amazing.
Cheers,
Sebastian
  • 1 year later...
It should work fine in RS, it will give you a warning but you can ignore that, it will render the seq. You can promote the parameter as well (still will warn, just ignore)
if you frame starting something other than 1 you should use `padzero` function.
  • 3 months later...
