(Solved)POP: random drag per particle HELP
gangland
hello guys, i've an simple rain setup.
i would like to give them a little timming difence while they fall
i giving to each pop point an random value (using a pop vop).
when feeding into pop drag using and using an simple point vex expression it stand still.
any clue about??
thanks in advance.
cheers
ps: i attach an simple .hip file
point_randrag_V00.hipFetching info...
Edited by gangland
  • gangland changed the title to POP: random drag per particle HELP
hey I don't know what I am doing here:
- in your popdrag, Inputs: Input1 Myself (still confused about this thing)
- set life to say 100, otherwise they 'stop' after about a second.
- should your popvop use id instead of ptnum ? dunno TBH.
hey, the life really do not matter, in the pop vop the particles are getting the random number like planned
the thing is in the pop drag, stil dkno to do
Edited by gangland
oh yeah, i see what you mean now, sorry.
What I've noticed is if you use wind velocity in the drag to simulate gravity....it doesn't 'drag'
if however you reset wind to 0 and use gravity...the drag will work....randomly!!!
Edited by Noobini
as bunker mentioned you can vary f@mass, alternatiely you can also vary  f@drag which will be automatically recognised
popdrag and popwind do the same thing, while popwind has just additional noise parameters so most of the times you are better off just placing popwind just in case you'll need the noise
here is example, based on your original file with f@drag varied, f@mass varied and popdrag and popwind  variations you can choose from and pick the setup that suits your preference
point_randrag_V00_mod.hipFetching info...
Edited by anim
  • Thanks 1
you're just avoiding using popdrag which is the problem.
Use the orig file, with popdrag, with Use VEX option, doesn't work.
with popwind used in the same way as popdrag in all respects, it works.
I'll answer meself LOL...
I just tried the orig file with popdrag now...it works !!! what the ???
well the OP used Use VEX option with the statement:
airresist = airresist * point(0, "rand_num",@id);
I cannot find that you use this anywhere in your scene. But I'm not here for a fight, you would pulverise me in a blink.
right, that's however irrelevant for the distinction between popdrag and popwind and on top of that it's wrong
even with first input set to Myself, you can't read point attribute by just substituting point number with i@id, that's pretty random
so it would either be (first Myself) and:
airresist *= point(0, "rand_num",@ptnum);
but "rand_num" should be randomized using i@id
or you can for short use:
airresist *= f@rand_num;
and forget about Myself stuff
but anyway, point of that file was to show easier ways and not have to use drag/wind VEXpressions as there are already attributes that modulate drag for you
Edited by anim
wow its cool to see difference approach for the same problem.
pretty clear!
thanks thomas
  • gangland changed the title to (Solved)POP: random drag per particle HELP
