abvfx Posted May 14, 2020 Share Posted May 14, 2020 Hey guys, i have a silly problem that i cant solve. I am using things like frizz, wave, set direction with the groom tools but i cannot use expressions to randomize the effect per primitive (per hair). I figured i should use something like rand($id); But nothing works in the parameter box. What can i put in the Fequence parameter that randomises it per hair? Quote Link to comment Share on other sites More sharing options...
Sepu Posted May 14, 2020 Share Posted May 14, 2020 (edited) create a prim attrib like `@frizzampscale = rand(@primnum);` before the frizz and then use it where it says `no override` pick the `guide attribute` in the amplitude dropdown. And just reading your question again, you can do this in any of the dropdowns btw. Edited May 14, 2020 by Sepu Quote Link to comment Share on other sites More sharing options...
anim Posted May 14, 2020 Share Posted May 14, 2020 On 5/14/2020 at 4:58 AM, abvfx said: What can i put in the Fequence parameter that randomises it per hair? Expand doesnt Random Frequency slider work for you? Quote Link to comment Share on other sites More sharing options...
abvfx Posted May 14, 2020 Author Share Posted May 14, 2020 (edited) On 5/14/2020 at 5:28 AM, Sepu said: create a prim attrib like `@frizzampscale = rand(@primnum);` before the frizz and then use it where it says `no override` pick the `guide attribute` in the amplitude dropdown. And just reading your question again, you can do this in any of the dropdowns btw. Expand Yea i thought of doing something along the same lines. Didnt work for me. Created it in the parameter and also did it via a wrangle on the prims. Still didnt work. Can you show me a screenshot, because if its working for you im doing something wrong. On 5/14/2020 at 5:51 AM, anim said: doesnt Random Frequency slider work for you? Expand Yea it just generate a random value on all the hairs. You would think it would generate a random frequencey per hair, that would be great. This behaviour also occurs with Amplitude too. The random Amp just randomises it but on all the primitives. If you use a mask then all that does is mask the effect leaving other unchanged. If i could maybe just randomise the seed based on the $id that would be the ideal solution. Edited May 14, 2020 by abvfx Quote Link to comment Share on other sites More sharing options...
Sepu Posted May 14, 2020 Share Posted May 14, 2020 it works for me in a prim wrangle as you can see I also use the attrib randomize. I use the 2 values distribution so I just get 1 or 0 but you can do whatever you want. 1 Quote Link to comment Share on other sites More sharing options...
abvfx Posted May 14, 2020 Author Share Posted May 14, 2020 (edited) Thanks @Sepu im gonna try this right now. edit:// yea so i tried this. I couldn't put it in the amplitude because that will just increase/decrease the effect, i need a random seed on the frequency or just even a random frequency for the prim. When i put it on the Frequency Guide Attr i get random behaviour. But when i switch it from two to continuous/discrete and other distribution is i get a much more random effect. So this work. I was thinking is there a more elegant way to do this. I don't think so. This is exactly what i need. Perfect Cheers Edited May 14, 2020 by abvfx Quote Link to comment Share on other sites More sharing options...
anim Posted May 14, 2020 Share Posted May 14, 2020 the Random Frequency and Amplitude parameters seem to work as expected they are both based on primitive i@id or if doesn't exist then on @primnum frizz_random_freq_amp.hip Quote Link to comment Share on other sites More sharing options...
abvfx Posted May 14, 2020 Author Share Posted May 14, 2020 (edited) Also it might behaviour as expected but that means i wont be able to get a different seed of the same frequency per id right? Random freq will give me a different hmm, weird. Every time i turned the Rand Freq up it did it all as one. Thinking about it, I have has this happen before with guide mask random tab where it will treat them all as one. Cheers for the example Tomas. I'm gonna take a look now. Edited May 14, 2020 by abvfx Quote Link to comment Share on other sites More sharing options...
abvfx Posted May 27, 2020 Author Share Posted May 27, 2020 So one thing ive realised that make things look a little "same-y". Is the frequency random is fine, but its applied all over. Is there a way to keep the frequency but adjust the seed per primitive? I tried using the @id but it doesnt work. Quote Link to comment Share on other sites More sharing options...
abvfx Posted August 3, 2020 Author Share Posted August 3, 2020 I still was unable to get decent randomisation and i wasnt the only one. Another groomer had the same problem, so he made a tool to replace it. Quote Link to comment Share on other sites More sharing options...
