osmanertasdiken Posted May 15, 2020 Share Posted May 15, 2020 Hi I'm trying to export a mesh with UV attribute with rop alembic export, but when I import it into Maya I am getting this error from Arnold '// Error: [polymesh] /geo1/uvunwrap1: incorrectly defined UV coordinates, missing either uvlist or uvidxs' In Maya, I can see that UV's are there though and it works when exported as obj, but I can't use that in order to get motion blur. Is there any other way I can export the sequence or anyone can let me know how can I fix this? I attached an example file. Any help would be much appreciated! ODforce_UVproblem.hipnc Quote Link to comment Share on other sites More sharing options...
Ultraman Posted May 15, 2020 Share Posted May 15, 2020 3 hours ago, osmanertasdiken said: Hi I'm trying to export a mesh with UV attribute with rop alembic export, but when I import it into Maya I am getting this error from Arnold '// Error: [polymesh] /geo1/uvunwrap1: incorrectly defined UV coordinates, missing either uvlist or uvidxs' In Maya, I can see that UV's are there though and it works when exported as obj, but I can't use that in order to get motion blur. Is there any other way I can export the sequence or anyone can let me know how can I fix this? I attached an example file. Any help would be much appreciated! ODforce_UVproblem.hipnc when export alembic and imported in maya do u have two uvset ? Quote Link to comment Share on other sites More sharing options...
anim Posted May 15, 2020 Share Posted May 15, 2020 how are you even exporting it? Since apprentice can't export .abc it's not easy to test your .hipnc file to replicte the issue Quote Link to comment Share on other sites More sharing options...
osmanertasdiken Posted May 15, 2020 Author Share Posted May 15, 2020 26 minutes ago, anim said: how are you even exporting it? Since apprentice can't export .abc it's not easy to test your .hipnc file to replicte the issue Oh I'm using education license not apprentice Quote Link to comment Share on other sites More sharing options...
osmanertasdiken Posted May 15, 2020 Author Share Posted May 15, 2020 39 minutes ago, Milad Savar said: when export alembic and imported in maya do u have two uvset ? Yes I do, UVs are showing up there, but when I hit render I get that error from Arnold Quote Link to comment Share on other sites More sharing options...
Ultraman Posted May 15, 2020 Share Posted May 15, 2020 18 minutes ago, osmanertasdiken said: Yes I do, UVs are showing up there, but when I hit render I get that error from Arnold select which one have uv island from uvset menu , and copy to second one .. i have this problems when exported but for quick fix i use copy stuff like image below ........ 1 Quote Link to comment Share on other sites More sharing options...
osmanertasdiken Posted May 15, 2020 Author Share Posted May 15, 2020 (edited) 57 minutes ago, Milad Savar said: select which one have uv island from uvset menu , and copy to second one .. i have this problems when exported but for quick fix i use copy stuff like image below ........ Legend!!!! Thanks a lot, Milad! That solved the issue, LIFE SAVER Edited May 15, 2020 by osmanertasdiken 1 Quote Link to comment Share on other sites More sharing options...
vectorhuter Posted June 2, 2020 Share Posted June 2, 2020 On 2020/5/15 at 6:08 PM, Milad Savar said: select which one have uv island from uvset menu , and copy to second one .. i have this problems when exported but for quick fix i use copy stuff like image below ........ i've got the same issue but this method doesn't work for me Quote Link to comment Share on other sites More sharing options...
vectorhuter Posted June 2, 2020 Share Posted June 2, 2020 On 2020/5/15 at 7:00 PM, osmanertasdiken said: Legend!!!! Thanks a lot, Milad! That solved the issue, LIFE SAVER how did you do man? Quote Link to comment Share on other sites More sharing options...
osmanertasdiken Posted June 6, 2020 Author Share Posted June 6, 2020 On 02.06.2020 at 2:13 PM, vectorhuter said: how did you do man? I literally just selected the 'uv' uvset and copied it over to map1. For some reason, it didn't work perfectly with the displacement textures later on. So I ended up displacing the geo in Houdini as well. If you can upload your alembic I can take a look Quote Link to comment Share on other sites More sharing options...
