yasinesin Posted June 1, 2020 Share Posted June 1, 2020 Hi guys! When i'm watching MvsM works, i saw this effect. Im thinking ''How did they do, how can i make in Houdini?'' I didn't find a keypoint to follow. Any thoughts? Thanks! Ref--4seven_~_On_Screen_Presentation.mp4 Quote Link to comment Share on other sites More sharing options...
skomdra Posted June 1, 2020 Share Posted June 1, 2020 This can be done in sops. I have to think exactly how, but my guess would be, try with bend sop which has direction driven by noise, or I would try to do some sort of 2D noise displacement with a falloff attribute to keep the bottom at place and top part movable. This can be with lines and sweep nodes turned into geometry. Plenty of ways. But you have to dig into sops and experiment, first. Try MOPs, cgwiki, there are plenty of resources out there. Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 1, 2020 Share Posted June 1, 2020 5 years old file maybe it Helps old_deform.hipnc Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted June 1, 2020 Share Posted June 1, 2020 Hi Yasin, try calculate bitangents along the outline curve, bricker divide and extrude. Move pieces to the center plus offset them by their bitangent vector and bend them based on noise. Make sure to hit play! bars_motion.hipnc Quote Link to comment Share on other sites More sharing options...
yasinesin Posted June 2, 2020 Author Share Posted June 2, 2020 Thank you all! I will check them all. @konstantin magnus @Librarian @skomdra Quote Link to comment Share on other sites More sharing options...
yasinesin Posted June 5, 2020 Author Share Posted June 5, 2020 Hi. Im trying to understand whats going on your file. This effect excatly what i looking for. But i can't understand 'For-Each Subnetwork' part. I trying to rebuild in H 7.5 and For-Each nodes are very different i think. I watched H15 and H16 Forloop masterclass but i cant figure out your For-Each nodes. Can you explain why do you use For-Each Subnetwork and how can rebuild in H17.5? Thanks! @Librarian Quote Link to comment Share on other sites More sharing options...
nuki Posted June 6, 2020 Share Posted June 6, 2020 hey, i just recreated the thing with a foreach loop and bend deform er in h18. You just need to mark the columns with a "class" prim attrib (eg. with the connectivity sop) deform.hipnc Quote Link to comment Share on other sites More sharing options...
