[VEX] Stacking points one above the other using atrrib size
esnaacho
Hello wizards, i have a little problem, and im not able to understand why my code doesnt work.
I have:
-a couple of points,
-each with a vector attrib "size".
-some code in a wrangle to order the points one above/under(direction shouldnt matter because im taking the absolut value, right?) the other without modifying the first point (0):
if(@ptnum > 0){
    vector last_point_size = point(0, "size", @ptnum-1);
    vector last_point_pos = point(0, "P", @ptnum-1);
    @P.y += ( abs(last_point_size[1]) + abs(last_point_pos[1]) );
Here before/after the wrangle. Tint in blue everything that doesnt change.
What am i doing wrong?
Thanks in advance for your time.
1 hour ago, fencer said:
How about calculate real size of every letter and shift based on it? Looks like you are trying to do the same but I am not sure about you idea.
ltower_v01.hipnc
Thank you . i would look into it.
1 hour ago, Noobini said:
I'm not really contributing anything but just FYI there's Labs Align and distribute which does in all 3 axis (with spacing)...just in case you wanna dissect its innards.
thanks man! i was looking for that, i saw it in a video a long time ago, but i couldnt remember the node name, and i dont remember the video either. lool thanks !
I think i found out the problem.
In the loop inside the wrangle:
if(@ptnum > 0){
when its in Point(0) - nothing happen
when its in Point(1) - last_point_pos = Point(0)'s position. apply new pos. OK
but when its in Point(2) - last_point_pos = Point(1) without the previous modification, so point 1 and 2 end up overlapping.
ltower_v01.hipnc
finally, problem solved. With just one wrangle. Your hip file was very useful. thanks !
I had to calculate the total size of all previous points, then adding the current size.
float total;
for(int i=0;i<@ptnum;i++){
    vector last_point_size = point( 0, "size", i );
    total += last_point_size[1];
@P.y = ( total + ( v@size[1]/2) );
Thanks everyone :)
Edited by esnaacho
changed variable name for easy understanding
