Viewing Additional UV Maps
Malak1000
I'm trying to view an additional UV map. uv (a 3flt) views just fine. However uvWind (also a 3flt) refused to appear in the UV Viewport dropdown.
I created a third with the UV Texture node - uvWind1 - and that show up just fine.
Though I notice that as well as being a 3 channel float like the others Houdini has tagged it a Tex.
How can you tag an attribute as a Tex so Houdini treats it as a UV channel in the viewport?
Thanks!
The VEX function you are looking for is 'setattribtypeinfo'. In your case to set the attribute type of uvWind to texture coordinates you'd need to create a Vertex Wrangle with the line:
setattribtypeinfo(0, "vertex", "uvWind", "texturecoord");
