Camera From 3dsmax To Houdini
kubabuk
Hi there,
Hope some of you find this otl useful, I've just uploaded that on SESI exchange.
The otl brings animated camera from 3dsMAX to Houdini (transformations, rotations and focal length). The otl comes with a script which saves channels from max.
All you have to do is to select camera in MAX and run the script.
At this moment file is generated with cc extension so renaming to *.chan is needed. You also have to get rid of all camera descriptions at the beginning and leave only chan data.
Make sure that frame rate and aperture (horizontal) are the same
cheers
kuba
  • 3 weeks later...
  • 3 weeks later...
Thanks Kuba,
Your otl works nicely. I had to change one thing to get some longer animations saved out from MAX. Instead of copying the string in the loop, I changed things so that the chan is written directly. This stops out of memory crashes and improves performance for larger animations.
			-- outString = (outString +	nFrame as string + "\t" +
						outString = (nFrame as string + "\t" +
										oCameraPosX as string + "\t" +
										oCameraPosY as string + "\t" +
										oCameraPosZ as string + "\t" +
										oCameraRotX as string + "\t" +
										oCameraRotY as string + "\t" +
										oCameraRotZ as string + "\t" +
										focal as string + "\t" +
										oCameraApertureX as string + "\t" +
				 						maxRate as string + "\t" +
										oCameraAspect as string + "\t" +
										oEnd as string + "\n" )
						format outString to:out
		-- format outString to:out
-Drew
There's an update of the otl on SESI exchange.
TX, TY, TZ
RX, RY, RZ
Focal Lenght
Aperture
Frame Rate
Camera Aspect Ratio
Animation Length
is supported
cheers
kuba
