samvac Posted July 16, 2020 Share Posted July 16, 2020 Hi I'm trying to control the restscale attribute using a custom attribute, so i can animate a noise and have it inflate depending on the color / custom attribute. I have added a vellumconstraintproperty and tried to use vex to transfer my atribute. But this is where i'm getting stuck. any help would be amazing. thanks VELLUM_INFATE_TEST_04.hiplc VELLUM_INFATE_TEST_04.hiplc Quote Link to comment Share on other sites More sharing options...
Gorrod Posted July 16, 2020 Share Posted July 16, 2020 I don't know much about how to control vellum correctly but I had a look at your file and it seems like the "pressure" type constraint is per piece, so there is only a single primtive for your entire sphere. You can't control the pressure on a per point basis. You would rather have to do the exact opposite and increase the restlength of every other constraint that is not pressure and increase the pressure at the same time to have an uneven amount of bloating. This might not be the ideal way of doing this but it might be what you're after: VELLUM_INFLATE_TEST_04.hipnc Quote Link to comment Share on other sites More sharing options...
samvac Posted July 16, 2020 Author Share Posted July 16, 2020 YOU ARE A GENIUS !! X Quote Link to comment Share on other sites More sharing options...
samvac Posted July 17, 2020 Author Share Posted July 17, 2020 I've tweaked the setup, but i just wanted to say a mass ive thank you for your help. Really appreciated x VELLUM_INFLATE_BY_ATTRIB.hipnc Quote Link to comment Share on other sites More sharing options...
samvac Posted July 17, 2020 Author Share Posted July 17, 2020 more refined VELLUM_INFLATE_BY_ATTRIB.hipnc Quote Link to comment Share on other sites More sharing options...
evadedesign Posted August 6, 2020 Share Posted August 6, 2020 On 17/07/2020 at 12:26 PM, samvac said: more refined VELLUM_INFLATE_BY_ATTRIB.hipnc Hey guys I used exactly the same technics you developped here to inflate some objects on a scene. Do you know what can I tweak to increase the "inflate" effect ? Like in the GIF attached the object seam to inflate on the very first frame but then the inflation isn't sufficient to blow in all the object and have that cool "blobby" result. It would be awesome if at least the inflated black area shape would be way more like a fully inflated balloon. How can I do that ? Thanks in advance !! Quote Link to comment Share on other sites More sharing options...
samvac Posted August 6, 2020 Author Share Posted August 6, 2020 Hey There If you send me your hip i can have a look for you Quote Link to comment Share on other sites More sharing options...
evadedesign Posted August 6, 2020 Share Posted August 6, 2020 24 minutes ago, samvac said: Hey There If you send me your hip i can have a look for you Hey ! yeah sure ! here is the file ! The mesh is not exactly the same as the GIF in my previous post because in the GIF it was a fbx file however the reaction is pretty similar with not a strong inflated effect. It would be awesome to get some balloon/cloth like inflation. HUUUUGE thanks in advance INFLATE_ROCK.hiplc Quote Link to comment Share on other sites More sharing options...
samvac Posted August 6, 2020 Author Share Posted August 6, 2020 everything was set up correctly, just made a few tweaks to the cloth bend stiffness and pressure stiffness INFLATE_ROCK.hiplc Quote Link to comment Share on other sites More sharing options...
evadedesign Posted August 6, 2020 Share Posted August 6, 2020 14 minutes ago, samvac said: everything was set up correctly, just made a few tweaks to the cloth bend stiffness and pressure stiffness INFLATE_ROCK.hiplc Oh thank you so much !!! This is working like a charm with the rocks and other collider objects Quote Link to comment Share on other sites More sharing options...
