ElemKlimov Posted July 17, 2020 Share Posted July 17, 2020 so i create a subnet with a few options in the parameter interface. outside that - i created 3 options joined by a switch. so i have 2 questions. 1) how do i create an HDA that keeps my current menu from the subnet and include that with a menu for the switch? i hope i am asking that right. 2) rather than having a slider for the switch - is there a way to create a toggle button for each option? Quote Link to comment Share on other sites More sharing options...
sant0s81 Posted July 18, 2020 Share Posted July 18, 2020 (edited) You can just create a parameter to control the switch (integer with 0,1,2 or a menu for example) or drag and drop the switch parameter in the Parameter Interface. edit: ah, just saw you dont want a slider a toggle, at least I think so, makes no sense since the switch only goes for 0 or 1 or 2 or 3 etc... Dont know if a switch could also have 0 and 3 at the same time. Maybe try with a menu? And check the screenshot to disable that option: Edited July 18, 2020 by sant0s81 Quote Link to comment Share on other sites More sharing options...
ElemKlimov Posted July 18, 2020 Author Share Posted July 18, 2020 thanks @sant0s81 - i'll give this a try. Quote Link to comment Share on other sites More sharing options...
