Vellum Frame
jonidunno
Hey all,
I need help with something I think should be relatively easy but cannot figure it out. I want to drop a picture frame in with strings attached using vellum. I have set up the wires but cannot figure out the correct approach to attach to the frame. I have a attached the beginning of my set up maybe someone can help me out or give me some advice! Thanks!
vellum_frame_jl_01.hiplc
you could also stitch to prim instead of edge as I've got...
if stitching by prim then it's prim 2 (the ropes are 0 and 1) but I think using border edge is more intuitive ? depends on the person i guess.
Also, I forgot, in your vellumcloth for the picture frame, crank CompressionStiffness to 1e+10, otherwise if it was colliding with something, it might 'compress'
Edited by Noobini
  • Thanks 1
