underscoreus Posted July 28, 2020 Share Posted July 28, 2020 Hey guys! I was wondering if it is possible (and if so, how to) add tools to a shelf from a file on disk. I have written some custom tools on my other computer and stored each tool to a separate .shelf file on disk and I thought it would be a simple manner to add these tools back into a custom shelf on another computer but it does not seem to be the case. Dragging and dropping the .shelf file onto the shelf does not recreate the shelf tool and I cannot see the tool in the list of tools in the "Edit Shelf Tab > Tools" window. Any ideas? Do the .shelf files have to be in a specific folder on disk? The folder I currently use is the "toolbars" folder where the other shelves are stored. Thanks for the read, Stay safe out there! Quote Link to comment Share on other sites More sharing options...
kiryha Posted July 28, 2020 Share Posted July 28, 2020 Probably you will need to run Houdini via Python wrapper, where you can set up necessary environment variables, the path to shelf etc. 1 Quote Link to comment Share on other sites More sharing options...
DonRomano Posted July 28, 2020 Share Posted July 28, 2020 Make a folder with your .shelf file (the one you have in $HOME/toolbar) and put this in the houdini.env : HOUDINI_TOOLBAR_PATH = "D:/Path/To/My_Houdini_Tools/Shelves";& In theory it should work; Or you can copy your .shelf file in the /toolbar folder in $HOME. Cheers, 1 Quote Link to comment Share on other sites More sharing options...
underscoreus Posted July 29, 2020 Author Share Posted July 29, 2020 (edited) On 7/28/2020 at 8:33 AM, DonRomano said: Make a folder with your .shelf file (the one you have in $HOME/toolbar) and put this in the houdini.env : HOUDINI_TOOLBAR_PATH = "D:/Path/To/My_Houdini_Tools/Shelves";& In theory it should work; Or you can copy your .shelf file in the /toolbar folder in $HOME. Cheers, Ah... soooo this is awkward. The answer was a combination of this and me misreading the list... I put my initials MB in front of all my tools names, but not in the label and I have been looking at the label section of the "Edit shelf > Tools" list. Thanks for the reply, sorry for the confusion Edited July 29, 2020 by underscoreus grammar... Quote Link to comment Share on other sites More sharing options...
