Merge various objects/primitives into single object/mesh
jdiazsaezwd
Hello, noobie question. I have a model of a petal, I wanted to add some points and hairs, animated and did a vellum sim but the points/hairs snap out of the petals and fly off, I tried to use fuse but doesn't work. any ideashow to merge the objects so the points stick to the surface in the sim? maybe a rest position and then deform points? I don't know what would work. If any of you have any idea I would appreciate the help, thanks :)
petalo.hipFetching info...
Edited by jdiazsaezwd
I couldn't be stuffed trying to understand your logic, don't take it the wrong way but I just think it's a bit overcomplicated
if all you want to achieve is a bit of hair on animated cloth, then here's a basic setup:
- I left the hair/rope strand very very soft...you can easily stiffen it.
vu_HairOnCloth.hiplc
vu_HairOnCloth.hiplcFetching info...
I apologize for my grammar, I'm not very good at explaining myself, I don't want the hair animated, just the petals, and the hair just attached to the surface, to save some sim time too. Thats why I was thinking about rest position and deform points, but im very noobie, I will try you set up and check the simTime, Thank you
