Add AOVs to ROP
garf
I recently did something like this but for a redshift ROP.
What I did is that I just use the parm().set() function on that parameter, it acts just as a normal number parameter so you don't have to go the way of dealing with the whole getting a list of all the parms, adding an instance of a parm and then reapplying the new list of parms to the node.
If you'd be interested you can have a poke at the shelf tool I made (assuming you are doing this with python):
https://github.com/Underscoreus/Rs_AOV_Transfer
Hope it can help :)
