garf Posted July 31, 2020 Share Posted July 31, 2020 I've done it before but can't find my old script. How do I script adding instances/AOVs/imageplanes on a ROP? 1 Quote Link to comment Share on other sites More sharing options...
eimk Posted July 31, 2020 Share Posted July 31, 2020 Use the insertMultiParmInstance() function on the AOVs parameter 1 Quote Link to comment Share on other sites More sharing options...
underscoreus Posted August 3, 2020 Share Posted August 3, 2020 I recently did something like this but for a redshift ROP. What I did is that I just use the parm().set() function on that parameter, it acts just as a normal number parameter so you don't have to go the way of dealing with the whole getting a list of all the parms, adding an instance of a parm and then reapplying the new list of parms to the node. If you'd be interested you can have a poke at the shelf tool I made (assuming you are doing this with python): https://github.com/Underscoreus/Rs_AOV_Transfer Hope it can help Quote Link to comment Share on other sites More sharing options...
