Kvothe Posted August 18, 2020 Share Posted August 18, 2020 I'm not super experienced with rendering, and I like what I've heard and seen from Renderman, but wow it look difficult to learn. Is it too impractical for a relative newbie ? How would one go about learning it, if new to rendering altogether? Quote Link to comment Share on other sites More sharing options...
schwungsau Posted August 23, 2020 Share Posted August 23, 2020 RenderMan is like most modern render engine. with path tracing you getting very good results but RenderMan is the most flexible render engine. if wanna speed your render 3 times or 10 times, you can dig into a rabbit hole. so have completely understood the rendering at the beginning, only if you optimize hell of it, you will learn/need different techniques (bi directional path tracing, manifold etc...) but this makes rendering like 4-5 times faster then Arnold/karma. thats a good start : for optimizing etc... Pixar Renderman sites have some good tutorials. and there are dozen of sites, which teach physicals based shading etc... it applies to all modern render engine https://marmoset.co/posts/basic-theory-of-physically-based-rendering/ 1 Quote Link to comment Share on other sites More sharing options...
Kvothe Posted November 8, 2020 Author Share Posted November 8, 2020 On 8/23/2020 at 4:00 PM, schwungsau said: RenderMan is like most modern render engine. with path tracing you getting very good results but RenderMan is the most flexible render engine. if wanna speed your render 3 times or 10 times, you can dig into a rabbit hole. so have completely understood the rendering at the beginning, only if you optimize hell of it, you will learn/need different techniques (bi directional path tracing, manifold etc...) but this makes rendering like 4-5 times faster then Arnold/karma. thats a good start : for optimizing etc... Pixar Renderman sites have some good tutorials. and there are dozen of sites, which teach physicals based shading etc... it applies to all modern render engine https://marmoset.co/posts/basic-theory-of-physically-based-rendering/ Is it much harder than Arnold? How much harder? Quote Link to comment Share on other sites More sharing options...
flcc Posted November 8, 2020 Share Posted November 8, 2020 Even if this is not quite true, it can be considered that the more flexible the engine is, the less easy it is to use. It all depends on what you want. Ease, speed, flexibility? If you are looking for an easy and fast renderer go to Octane. If you are looking for a powerful and flexible renderer go to renderman. (don't know about Karma yet). Between the two you can choose Arnold or redshift. The advantage of redshift is its speed, which does not require a lot of optimization work. Quote Link to comment Share on other sites More sharing options...
Howitzer99 Posted November 14, 2020 Share Posted November 14, 2020 I've used RenderMan for many years professionally, but for my own projects, I rely on Redshift for speed, and Arnold for higher quality (especially volumes). There are troves of information regarding any modern renderer online, so learning is much less of an issue these days. As Fred mentioned above, Redshift is pretty easy to use out of the box, and the implementation inside of Houdini is solid. You really can't go wrong with any of the renderers mentioned in these posts. And most offer free or trial licenses. Quote Link to comment Share on other sites More sharing options...
ahmedhindy Posted August 2, 2021 Share Posted August 2, 2021 On 11/14/2020 at 1:23 PM, Howitzer99 said: I've used RenderMan for many years professionally, but for my own projects, I rely on Redshift for speed, and Arnold for higher quality (especially volumes). There are troves of information regarding any modern renderer online, so learning is much less of an issue these days. As Fred mentioned above, Redshift is pretty easy to use out of the box, and the implementation inside of Houdini is solid. You really can't go wrong with any of the renderers mentioned in these posts. And most offer free or trial licenses. Arnold has higher quality volumes? does Renderman require alot of optimizations to match/ surpass the speed of Arnold? Quote Link to comment Share on other sites More sharing options...
Howitzer99 Posted August 6, 2021 Share Posted August 6, 2021 RenderMan used to need a lot more tweaking, especially when they were first introducing raytracing into the engine. These days, I'm mostly using Arnold and Redshift, so I'm about 2 versions behind for any advanced with RenderMan. All the renderers have free or trail licenses, so best to just jump in, and test with your scenes and see which one you feel most comfortable with. Quote Link to comment Share on other sites More sharing options...
