mavencolby Posted August 29, 2020 Share Posted August 29, 2020 Hey guys, I'm copying this post from Reddit to get more exposure. Since you guys are pros, maybe you'll know the answer: I'm having an issue with my landscape material. I've got an HDA pulling in a landscape with six layers. I've setup each layer as a material function so I can blend each function in a material based on their layer name. The problem is the material only works with three layers at a time. I can't do more. This is what it looks like with three layers as expected: Three layers with blend mode set to Opaque The shader fails when I plug in more than three. It shades in a tiny square on the terrain (not shown here), the rest of the terrain is the standard checkerboard: Six layers fail with blend type set to Opaque The only way to view all layers is to set Blend Type to Alpha Composite, however I completely lose my directional lighting: Six layers with blend type set to Alpha Composite (no directional lighting) It must be something with my layering weights.. I just can't figure this out for the life of me. Here are my layer settings: Layer Blend settings Let me know if you've run into this issue; I'm sure it's an easy fix. Thanks guys, Colby Quote Link to comment Share on other sites More sharing options...
sant0s81 Posted August 29, 2020 Share Posted August 29, 2020 Did you try to plug a Constant3Vector into the layer blend? Just to check if that works. I just tested a heightfield with 6 different masks and it works. Quote Link to comment Share on other sites More sharing options...
mavencolby Posted August 29, 2020 Author Share Posted August 29, 2020 Hey, I'll try that out and see if it works. I'll update here. Thanks Santos Quote Link to comment Share on other sites More sharing options...
mavencolby Posted August 30, 2020 Author Share Posted August 30, 2020 So it seems to be working for base color now, but once I apply any other material attribute it won't shade the terrain. I made a low-res terrain to test. This is the material: And this is the texture (it's the same default for testing, but it's working for base color): However, when I apply ANYTHING other than Base Color, the shader fails: I'm just copying the Quixel default material into the material function for each layer: Any idea why this is only working with Base Color? Quote Link to comment Share on other sites More sharing options...
mavencolby Posted August 30, 2020 Author Share Posted August 30, 2020 I just tried separating each material attribute and combining them individually via layer blend, however this still did not work... Again base color works fine with this method: I'll keep messing around. Quote Link to comment Share on other sites More sharing options...
mavencolby Posted August 30, 2020 Author Share Posted August 30, 2020 Got it working!! So I needed to change the Sampler Source for each texture sampler to: Shared: Wrap. That and using a TenLayerBlend did the trick! And the texture sample node: 2 1 Quote Link to comment Share on other sites More sharing options...
darklordstudios Posted February 28, 2021 Share Posted February 28, 2021 (edited) Hello, I am in a similar boat here and see that you used a TenLayerBlend. What are the inputs at the bottom and how did you create them. I understand the material inputs but the bottom ones elude me. It says sample but what is it a sample of? I feel like I am close!! Regards, Dan Edited February 28, 2021 by darklordstudios Quote Link to comment Share on other sites More sharing options...
