isah_voodoo Posted September 4, 2020 Share Posted September 4, 2020 Hello, Im following the rohan dalvi tutorial here: Im trying to break the pin points over time by animating the constraints properties inside the vellum solver. However it still stays attached even when I animate it down to 0. I made sure to set the Pin type to "Soft" like the way he does it. Any help would be greatly appreciated. Thank you vellum_breaking_pins.hipnc Quote Link to comment Share on other sites More sharing options...
Ultraman Posted September 4, 2020 Share Posted September 4, 2020 vellum_breaking_pins1.hipnc Quote Link to comment Share on other sites More sharing options...
isah_voodoo Posted September 4, 2020 Author Share Posted September 4, 2020 @Milad Savar Hi, I opened up your file and i'm still not getting anything. Which Houdini version are you using . Im using 18.0532. Thanks Quote Link to comment Share on other sites More sharing options...
Ultraman Posted September 5, 2020 Share Posted September 5, 2020 hi , i'm using same version " 18.0532 " - but i upload your file again , hope work this time. vellum_breaking_pins1.hipnc 2 Quote Link to comment Share on other sites More sharing options...
isah_voodoo Posted September 5, 2020 Author Share Posted September 5, 2020 @Milad Savar Wow awesome. Yeah that works thank you. What exactly did you do differently in this file to get it to work ? I noticed that the difference between your file and my original file is that you created a stretch group and used it in the constraints property. Why do we need to do this in order for it to work ? A bit confusing. Quote Link to comment Share on other sites More sharing options...
Ultraman Posted September 5, 2020 Share Posted September 5, 2020 On 9/5/2020 at 2:05 PM, isah_voodoo said: @Milad Savar Wow awesome. Yeah that works thank you. What exactly did you do differently in this file to get it to work ? I noticed that the difference between your file and my original file is that you created a stretch group and used it in the constraints property. Why do we need to do this in order for it to work ? A bit confusing. Expand active the group feature in pin target "p_streatch " and in dop environment with the property node removed only p_streatch group constraint . when you worked with the many pin constraint or something else , is better use group stuff for mange data . but in this case if u leave group name in the property node , u have same result (effect on all constraint ) . one thing i remember in your hipfile , break type was off i think but must be active. hope it's useful - 1 Quote Link to comment Share on other sites More sharing options...
isah_voodoo Posted September 6, 2020 Author Share Posted September 6, 2020 @Milad Savar Thank you. that helps. 1 Quote Link to comment Share on other sites More sharing options...
