KavinduMathish Posted September 26, 2020 Share Posted September 26, 2020 Hello. So as you can see in the below screenshots i created a point group named "outer" and tried to apply a material to that group using a Material SOP. But it said the group does not exist and it did not work. Then i ran the wrangle which i used to create the "outer" group over primitives instead of points and created a prim group named "outer". Then it worked as i expected. The Material SOP picked the group name "outer". So my question is doesn't the Material SOP work over point groups? I went through the Material SOP help doc and it said "Assigns a material to a group of primitives or points." I am a bit confused. Do i need to adjust any specific settings in order for it to work over points? Thank You! Quote Link to comment Share on other sites More sharing options...
bunker Posted September 27, 2020 Share Posted September 27, 2020 you have to use prim groups instead. Quote Link to comment Share on other sites More sharing options...
anim Posted September 27, 2020 Share Posted September 27, 2020 If you switch Attributes drop-down to Point attributes it should work for point groups In the past I think Mantra didn't work with point based shop_materialpath so there is a chance it still doesn't, but if I remember correctly Redshift did, I haven't tried for a while though Quote Link to comment Share on other sites More sharing options...
martinkindl83 Posted September 27, 2020 Share Posted September 27, 2020 I think now Mantra does, Arnold doesnt work with shop_materialpath on points Quote Link to comment Share on other sites More sharing options...
