Houdini -> Quixel Mixer -> UE4
sant0s81
Hey,
I have a model of a cannon in Houdini:
The model is seperated in all its different parts.
When I export that model as a .fbx and open in Quixel Mixer, I get the message, that multiple UVs are not supported.
When searching for tutorials how to open a Houdini model in Mixer, I find some examples where they bake an ID mask/map of that model and only use one UV.
But how can I make from all that parts just a single part with a single texture and than bake out the ID map?
Are there some tutorials, that explain that workflow?
I think I have to use the game dev tools in Houdini to bake the textures.
I could export every part as a single model, texture in Mixer and use them in Houdini - but is there a way, that I have the model in one piece in Mixer?
I have no idea, what I have to search for - new land for me...
Thx,
sant0s
edit:
Tutorials like this here, https://www.youtube.com/watch?v=eCOhllpXmaY
have all the geometry in one geometry node.
So actually, I have to copy all the geometry into one geometry instead of having multiple nodes.
But of course I lose all the transformations.
Is there maybe a way, to get all the geometry into one node without losing the UV information and transformation?
Edited by sant0s81
Sry for bothering again..
I am just testing some different ways, I only need that ID map.
I tried to object mege the geometry and used groups to give different colors to than have kinda like a ID map:
Would that work or is there a more elegant method?
I remember in 3D Coat there was something that recognized the UVs and gave a game ready ID map.
Or would Cryptomatte be the way?
Edited by sant0s81
  • 2 weeks later...
On 9/29/2020 at 3:47 AM, Librarian said:
And remember if you cant Find something here or on SideFX forum just use  qiita.com  because first Asia than REST  ...Asia Students :wub:
Have FUn
But we don't know the language..
On 9/29/2020 at 3:14 AM, Librarian said:
Hope it Helps!
play with this file and see HDA and how to separate
Car.rar
This is is not the answer to the question about UV's, the Valley scene too...
______________________________________________________________________________________________
It looks like it's been a problem for a while for them.
https://help.quixel.com/hc/en-us/community/posts/360009633797-When-will-Multiple-Texture-Sets-be-available-in-Mixer-
You can try procedurally color the model by UV connectivity or smth like that if it helps.
randUVcolor.hiplc
  • Thanks 1
Okay,
I think its working now....
Just had to ad the normal Baker, not the simple Baker - and add Cd as a custom channel.
I used @Deviner 's example and only added the Maps Baker with the custom channel.
Thx for the help guys :)
edit: I gonna try if it works like an ID map.
But maybe there is a way to group or connect the UVs before?
Now I have quite a lot of color IDs... I dont know if Quixle Mixer can multi select different colors...
But I let you know if it works :D
Edited by sant0s81
Hey @sant0s81, I'm glad it worked.
I reckon the best way would be to create base colors procedurally and then select the areas you need the most manually.
if you have a "path" or "name" attribute you can split it in a better way tho with smth like this.
@Cd = rand(random_shash(s@name));
randUVcolor_v001_t01.hiplc
