Cushion pattern
Vinz
Hello Odforce
Would anyone have an idea on how to approach this pattern (I would prefer to model it than displace render it). This is a watch bracelet.
I have made multiple disastrous attempts which are not worth posting here.
Many Thanks
@konstantin magnus
I know the rest but kind like you sweet spot for the double sweep :)
Obviously you give that and there will always people will ask for some fancy pillow
  ________________________________________________________________
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
 http://fr.linkedin.com/in/vincentthomas
Expand
I know, the double sweep put me on my butt.. the first one looks like it failed and then.. magic. I still haven't worked it out..
Now I need to make the tread to poke in and poke out of the leather.. I am thinking of using a sin wave function but likely beyond my capacities.. I'll give it a shot
Vincent to Vincent... Here's one way, hip attached
You could easily change the lacing design from this setup. Ok, there is more than 5 nodes here ^_^
Vincent Thomas (VFX and Art since 1998) (Availble end of November)
image.thumb.png.eb643c05454194faf9a7b61b2d8e5237.pngimage.thumb.png.41d29090a3e124d5e2eeb7683b5bb9fd.png
laceexample_vt.hipncFetching info...
Edited by vinyvince
Hy Vince, really nice. I learned a lot reading through the nodes.
So I tried to combine Konstantin's take and apply the threads.. taking a little shortcut.
The 2 problems that I have left are:
- I need to orient the loops in the direction of the lines to match the reference above
- I am having a hard time getting a nice smooth twist for the wires
If you can
Cheers
Cushion_leather_01.hipnc
@N = set(0, 0, 0);
v@binormal;
i@group_group1 = 0;
if(@ptnum != 0 && @ptnum != @numpt-1)
    vector p0 = point(geoself(), "P", @ptnum-1);
    vector p1 = point(geoself(), "P", @ptnum+1);
    vector v0 = normalize(p0 - @P);
    vector v1 = normalize(p1 - @P);
    v@binormal = normalize(cross(@N, v1));
    if(dot(v@binormal, v0) < 0)
        i@group_outerPoint = 1;
Make two Groups/corresponding sides  and Shift, Play with Normal's. Have Fun
  On 11/22/2020 at 8:21 PM, Vinz said:
Cool.. yeah I will try to implement your function.. get back to you soon
Thank you Tesan
Expand
There is many way, but if your case, no curve banking or need to build parallele transform, just add 90degree roration on Y at your transform2, and that's it :)
  On 11/24/2020 at 4:52 PM, vinyvince said:
PS: By the way, if you want more control on the deformation, you could just replace the last line of the def plane  wrangle by something like this
v@P.y += chramp("adjust",fit(dist,0,radius,0,1))*ch("mult");
Expand
Is this for the twist of the string itself?
I applied your function to the wrangle. Works real nice with 'round' curve. Gives me that master control.
Tx
Edited by Vinz
