replace point by object
Nemiko
11 minutes ago, Librarian said:
@Nemiko Maybe It Helps
int hitprim;
vector hitprimuv;
xyzdist(1, v@P, hitprim, hitprimuv);
v@P = primuv(1, "P", hitprim, hitprimuv);
test_11.hiplc
Almost what is needed, but the lines are still inside the geometry, I wanted to make the lines flow around like an object
That is, I understand that it is necessary to somehow calculate the distance of the object's surface and shift it along the normals from the normals of the object itself, but how can I not understand how to do thisimage.png.b6482ec858d8b05d6dbfed5b95201953.png
