HDA with multiple outputs
ManHatTan
3 minutes ago, Librarian said:
Check the built-in Vellum nodes, they're HDAs and have multiple inputs&outputs. Just do as they do.
Hi. I need to the outputs to "output" in the top level obj context (sorry if I get the terminology wrong). The vellum nodes work inside geo nodes, right?
if you want to build HDA with 2 outputs (heightfield + geometry) you have to go to SOP context. I doubt you can create it on object level.
Edited by vicvvsh
