Emit pyro outwards (not upwards)
Mark01
Hey everyone,
I have an animated object moving in a sin wave type motion. I am trying to emit smoke outwards from it. At the moment the smoke is just rising in Y which isn't what I want.
Any suggestions? :)
+ i made an awful unnecessary diagram, it might help or it might be confuse matters :lol:
  • 3 weeks later...
Thanks so much for that that hip file is really helpfu!
So that was working but rather than emitting from a line, I am emitting from particles. So I would need the the particles velocity to also point outwards.
Plugging a scatter into the line and then feeding that straight into the pointwrangle2, I can't seem to get your setup working?
My method for calculating if there is a left- or right-hand turn requires a curve, because I am comparing the position and normal direction from the previous and next points. If you want to use particles you need to scatter them after the calculations on the curve like @ryew said.
EDIT: Added a couple of lines to the curve calculation so curves with very sharp turns get correct bending ratios.
curve_smoke_outwards_dl_v2.hipnc
Edited by dleonhardt
