Long loading of complex Digital Asset
I created a rather complex Digital Asset. It consticts of ~2000 nodes, and also there is ~60 instances of another asset inside this asset.
I optimized it thought cleaning nodes throught performance monitor, and now It computes rather fast after loading, but LOADING takes nearly 10 seconds. It's became a real problem because in my hip file I need to use it rapidly many times.
Is there any way to speed up loading of asset?
And after creating every instance of this asset Houdini increases ram usage at ~500 mb, it's also a problem...
  • 4 weeks later...
Well, I remade my asset. The most heaviest operations rebuilded on vex. Asset works maybe 2 times faster. But still long initialization.
I found that if asset is constructed from many-many nodes, especcialy if it's another custom digital assets, it have a long time for initialization. But after that it computes quite fast. And Hip file also have a quite long time to open.
This is normal or not?
I think its normal that it gets slower the more nodes you have. I once had a scene with literally thousands of nodes, mainly inside HDAs and nested HDAs (the vellum nodes are particularly nasty, many of them contain sooo many nodes). It took a good 5-10min to open that scene.
