How to figure out the ridge line/curve on a terrain
microvswind
you can use Find Shortest Path SOP and make it prioritize convex curvature areas
since it's a bit ambiguous where should the ridges start and end you will need to provide a hint like start and end positions
here is an example of specifying start and end positions using simple curves and it will try to find the best path following ridges, if it doesn't you can always define long paths by multiple shorter ones
ts_mountain_find_ridges.hip
  • Like 2
  • 2 weeks later...
WOW .This is exactly what i want to get .Thank you so much and sorry for late reply .
