papsphilip Posted February 23, 2021 Share Posted February 23, 2021 Is there a node in COPS to warp textures based on an input? noise, another image etc Quote Link to comment Share on other sites More sharing options...
snoot Posted February 23, 2021 Share Posted February 23, 2021 This should do the trick.... (using vop cop generator). 1 Quote Link to comment Share on other sites More sharing options...
papsphilip Posted February 24, 2021 Author Share Posted February 24, 2021 nice!! this way you distort an input image with a noise. Would this work the other way around? Distorting a noise with an image. What i am trying to do basically is conform a noise to flow somehow around a black and white image (no gray values) Quote Link to comment Share on other sites More sharing options...
Krion Posted June 25, 2021 Share Posted June 25, 2021 (edited) On 2/23/2021 at 9:07 PM, snoot said: This should do the trick.... (using vop cop generator). Would you use : op:`opinputpath("../", 0)` ..to do this on the inputs of the COP VOP? If so; Why is there the COP Input VOP? Also: When I use that expression with the Color Map VOP Houdini crashes.. I try to do this because the Color Map VOP has the option to repeat/tile. (see odforce.net/topic/49062-tiling-in-the-cop-vop/) - On 2/24/2021 at 4:32 PM, papsphilip said: nice!! this way you distort an input image with a noise. Would this work the other way around? Distorting a noise with an image. What i am trying to do basically is conform a noise to flow somehow around a black and white image (no gray values) It seems hard to understand what you mean. Maybe you should provide some example of what you want to achieve. Edited June 25, 2021 by Krion Quote Link to comment Share on other sites More sharing options...
Richard Posted March 8, 2023 Share Posted March 8, 2023 Deform Cop should do what you need. Plug in your image to 1 and a noise to input 2. Use very low values or it becomes very distorted. Make sure to change the Deform Plane to C (for Colour) Quote Link to comment Share on other sites More sharing options...
