Like Sketch ?
Librarian
  On 3/14/2021 at 1:46 PM, Librarian said:
Expand
Good art work! You can also make curves follow the mesh topology by choosing directions towards neighbour polygons.
hatching_mesh.png.2e03c7daf24bb41557dce56f2487741d.png hatching_mesh_2.png.08eb1709b0ddc70867d3aac2da19202e.png
topo_flow.hipncFetching info...
topo_flow_only_curvature.hipnc
Edited by konstantin magnus
  • Like 4
  • 4 weeks later...
  On 3/13/2021 at 11:17 PM, konstantin magnus said:
The measure SOP has a principal curvature direction you could use for hatching.
sketch.hipncFetching info...
Expand
This is nice, thanks Konstantin.
I quickly did a test to combining with gradient,  interesting...
I guess i have to make a custom "triplanar"network to blend each gradient result for each component of my input vector to measure.
________________________________________________________________
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
 http://fr.linkedin.com/in/vincentthomas
  • 6 months later...
wow.. you are really incredible..
Please, what is this language in Attribute wrangle?
"string direction = chs('direction');
vector pos = v@P;
vector dir = point(0, direction, i@ptnum);
int pts[] = array(i@ptnum);
int steps = 30;
float angle = 1.0;
while(steps > 0 && angle > -0.1){
    steps--;
    pos += normalize(dir) * 0.002;
    int prim;
    vector uvw;
    xyzdist(1, pos, prim, uvw);
    vector dir_old = dir;
    dir = primuv(1, direction, prim, uvw);
    angle = dot(dir_old, dir);
    if(angle < 0.0){
        dir *= -1.0;
    int pt_add = addpoint(0, pos);
    append(pts, pt_add);
addprim(0, 'polyline', pts);"
thank you very much.
bests regards
Expand
It's Houdini's own shader language called VEX. Matt Estella provides an artist friendly introduction:
https://www.tokeru.com/cgwiki/index.php?title=JoyOfVex
The same programming can also be done visually using VOP nodes which is probably easier for starters.
