Max_Steven 5 Posted March 20 (edited) Hello, After searching the forum I managed to get points from the L system's leaf Now I want to instance leaves to those points, but even the point has Normal direction right, copy to points not give me the result I want It just point to the same direction. Can you point me where I did wrong? Thank you CopyToPoint_Normal.hip Edited April 5 by Max_Steven Share this post Link to post Share on other sites
Sepu 220 Posted March 20 promote your normals from vertex to point, that should do it. CopyToPoint_Normal.hip 1 Share this post Link to post Share on other sites
Max_Steven 5 Posted March 20 Wow thank you so much I tried to figure it out for days I have one question that if in the attribute create before L system i set the Normal is point not vertex then the Normal wont be calculated properly in the L system anymore. Is that L-system thing? I just wonder maybe there is a simple reason for that. Share this post Link to post Share on other sites
