Max_Steven Posted March 20, 2021 Share Posted March 20, 2021 (edited) Hello, After searching the forum I managed to get points from the L system's leaf Now I want to instance leaves to those points, but even the point has Normal direction right, copy to points not give me the result I want It just point to the same direction. Can you point me where I did wrong? Thank you CopyToPoint_Normal.hip Edited April 5, 2021 by Max_Steven Quote Link to comment Share on other sites More sharing options...
Sepu Posted March 20, 2021 Share Posted March 20, 2021 promote your normals from vertex to point, that should do it. CopyToPoint_Normal.hip 1 Quote Link to comment Share on other sites More sharing options...
Max_Steven Posted March 20, 2021 Author Share Posted March 20, 2021 Wow thank you so much I tried to figure it out for days I have one question that if in the attribute create before L system i set the Normal is point not vertex then the Normal wont be calculated properly in the L system anymore. Is that L-system thing? I just wonder maybe there is a simple reason for that. Quote Link to comment Share on other sites More sharing options...
