Digital Asset - Parameters Locked
Hello,
I am creating an digital asset for a personal project that I am working on. As soon as I saved the digital asset, all the parameters are locked and I cannot change it. Can someone please tell me how to edit those parameters?
I have attached a screenshot of edit parameter interface, in parameter description, you can see all of the fields are locked except for a few.
Thanks for your help
Try right-clicking on the node and click on "Allow Editing of Contents" and then right-click again and choose "Type Properties".
When dealing with an HDA it's important to use the "Type Properties" option to edit stuff since this actually edits the HDA itself. If you just use the normal "Edit Parameter Interface" you'll just be making changes to this one node, so if you make another of the same HDA it won't have the changes you made if you used the "Edit Parameter Interface" option.
That's awesome. Thanks a lot. It works now. :)
  • Thanks 1
