dolexd Posted March 20, 2021 Share Posted March 20, 2021 Hello, I am creating an digital asset for a personal project that I am working on. As soon as I saved the digital asset, all the parameters are locked and I cannot change it. Can someone please tell me how to edit those parameters? I have attached a screenshot of edit parameter interface, in parameter description, you can see all of the fields are locked except for a few. Thanks for your help Quote Link to comment Share on other sites More sharing options...
underscoreus Posted March 20, 2021 Share Posted March 20, 2021 Try right-clicking on the node and click on "Allow Editing of Contents" and then right-click again and choose "Type Properties". When dealing with an HDA it's important to use the "Type Properties" option to edit stuff since this actually edits the HDA itself. If you just use the normal "Edit Parameter Interface" you'll just be making changes to this one node, so if you make another of the same HDA it won't have the changes you made if you used the "Edit Parameter Interface" option. Quote Link to comment Share on other sites More sharing options...
dolexd Posted March 20, 2021 Author Share Posted March 20, 2021 5 hours ago, underscoreus said: Try right-clicking on the node and click on "Allow Editing of Contents" and then right-click again and choose "Type Properties". When dealing with an HDA it's important to use the "Type Properties" option to edit stuff since this actually edits the HDA itself. If you just use the normal "Edit Parameter Interface" you'll just be making changes to this one node, so if you make another of the same HDA it won't have the changes you made if you used the "Edit Parameter Interface" option. That's awesome. Thanks a lot. It works now. 1 Quote Link to comment Share on other sites More sharing options...
