importing abc files
By default the geometry is coming in as Alembic Delayed Load Primitives. Take a look at the "Load As" drop-down menu on either the File > Import > Alembic Scene dialog or the Alembic SOP. You can choose to unpack the geometry there.
@Renderhouse Try using the "alembic" node when importing alembic's instead of the file node.
Inside the alembic node you should have the options that DaJuice mentioned and it should solve your issue.
After you've made sure the alembics are not imported as packed alembic primitives, make sure that your viewport selection is set to primitives and you could also try to toggle the lock icon on the left side of your viewport under the arrow icon as this sometimes limits selection options.
