RBD Hold active attribute
gangland
Hello guys.
i creating an group to activate the pieces to start to fly.
im using an sop solver in the pre-solve input to create those pieces active=1
However while move outside the region bound. it loss this attribute and simple stop.
i tried to "hold" the attribute 1 using an max function, but i didnt work.
please help me
thanks in advance.
ps: i uploading an simples setup of this
hold_active_att.hip
  • 8 months later...
This helped me a lot as well as a houdini newbie. But I was wondering if theres a way to control or access the fractured pieces after the sim ?
Because as soon as I try to do something to the pieces after the sim, like "merge" the simulated parts as a separate group into another Geo SOP or Blast them after the sopsolver simulation, you're back to square one, and only the parts that are inside the Bounding object are imported or blasted.
One would expect the "active" group to be accessible, but no such luck. Maybe a setting or attribute that needs to be toggled or activated ?
thanks.
