vellum grains not shaded
Follyx
Can you post a picture of screencap of what you're seeing?  There's the black color you're setting for the activation, but I see shaded spheres as expected when that Cd is deleted in H18.5.499.  As long as you're removing the black color you previously set and are displaying sprites in your viewport's display settings (Geometry->Particles-> Display Sprites) then it's just the sprite shader SESI assigned to them
