creating bricks
14 minutes ago, Renderhouse said:
hi, i want to create bricks in this wall and want them to behave like bricks when collide, is it possible  ? and i create brick shape with divide and used facets by making them unique but its uniquing every single polygon !
u can Create Brick Cutter Pattern and use the Boolean SOP  ./
On 4/17/2021 at 8:28 AM, Renderhouse said:
hi, i was just trying to make a brick from that, but boolean seems like its not working the same , i have used shatter boolean , what should i do ?
this is the wireframe of the brick wall i made for the boolean
can share hip file
