Asset management in Redshift
Hi all,
Can anyone recommend a good pipeline or an asset library management tool to use with Houdini + Redshift?
Looking at alternatives, Mantra supports relatively simple FBX import and material conversion that (almost) works out of the box with material groups and such. C4D has an asset library to streamline asset management.
I tried creating the shelf tool described here but wondering if there's a better method since 2018:
I seem to struggle/spend way too long every time I need to import FBX.
What's your solution to asset management working with Redshift in Houdini?
Edited by sb526
