Guest Swann Posted April 2, 2008 Share Posted April 2, 2008 (edited) OK, now something SCARY KIDS, GO SLEEP NOW !!! Yup, to the right original geo, to the left, displaced version. BEAUTYFULL MONSTER Edited April 2, 2008 by SWANN Quote Link to comment Share on other sites More sharing options...
Jason Posted April 2, 2008 Share Posted April 2, 2008 SWANN said: OK, now somethin SCARY KIDS, GO SLEEP NOW !!! Yup, to the right original geo, to the left, displaced version. BEAUTIFULL MONSTER Hey SWANN, have you noticed how different (improved!) the quality of the image gets when you increase the Shading Quality of your objects? On most of the ink NPR renders I've tried with Mantra, it's very sensitive to Shading Quality. Quote Link to comment Share on other sites More sharing options...
Guest Swann Posted April 2, 2008 Share Posted April 2, 2008 (edited) Jason said: Hey SWANN, have you noticed how different (improved!) the quality of the image gets when you increase the Shading Quality of your objects? On most of the ink NPR renders I've tried with Mantra, it's very sensitive to Shading Quality. I will look closer to this. Thanks EDIT: Ok, here is the ShadingQuality Fight. Whitch is better ? Hm, let me just say that at 4 it renders about 8-10 minutes, I guess, on 1 it's only 44 seconds Edited April 2, 2008 by SWANN Quote Link to comment Share on other sites More sharing options...
RonensArt Posted April 2, 2008 Share Posted April 2, 2008 How can i install smd use the shader in Houdini? Where you downloaded it from? Ronen. Quote Link to comment Share on other sites More sharing options...
Guest Swann Posted April 2, 2008 Share Posted April 2, 2008 (edited) RonensArt said: How can i install smd use the shader in Houdini?Where you downloaded it from? Ronen. Look 10 posts from yours UP Edited April 2, 2008 by SWANN Quote Link to comment Share on other sites More sharing options...
Andz Posted April 2, 2008 Author Share Posted April 2, 2008 Great pineapples! I didn't have the time to put any UVs on the shader, that might be why it looks like that when you use the displace. I love the images! hehe, thanks for posting them... please keep them coming. Quote Link to comment Share on other sites More sharing options...
Guest Swann Posted April 2, 2008 Share Posted April 2, 2008 (edited) Andz said: Great pineapples!I didn't have the time to put any UVs on the shader, that might be why it looks like that when you use the displace. I love the images! hehe, thanks for posting them... please keep them coming. I added uvs for camera version but i it has to many parts to just add one to all to look good, that why I unpluged dots. Edited April 2, 2008 by SWANN Quote Link to comment Share on other sites More sharing options...
stevenong Posted April 2, 2008 Share Posted April 2, 2008 Very nice renders SWANN. Kudos to the shader too! Great stuff guys! Cheers! steven Quote Link to comment Share on other sites More sharing options...
Guest Swann Posted April 2, 2008 Share Posted April 2, 2008 (edited) Added uv to the version with displacement, a little better now, but still not the best results, maybe different mapping will help(especially for balls), or you can play with uv scale or with shader inside...But this is the story for another day. Now I have to look/learn how this shader is done. Cheers. Edited April 2, 2008 by SWANN Quote Link to comment Share on other sites More sharing options...
pclaes Posted April 2, 2008 Share Posted April 2, 2008 Nice renders & interesting shader! I like the way the ink shaders picks up the little noise details in the displacement. Reminds me a lot of early black and white comics. Quote Link to comment Share on other sites More sharing options...
Allegro Posted April 2, 2008 Share Posted April 2, 2008 Hey Swann, You should do something animated with this, it'd look cool up at the Side Effects gallery! Quote Link to comment Share on other sites More sharing options...
Guest Swann Posted April 2, 2008 Share Posted April 2, 2008 (edited) Andz said: Great pineapples!I didn't have the time to put any UVs on the shader, that might be why it looks like that when you use the displace. I love the images! hehe, thanks for posting them... please keep them coming. Could you explain this funtion: $dangle = max(abs(Du($x))+abs(Dv($x)), $MINFILTER); You just taked this function from somehere or it's all your Idea ? InlineVOP takes inputs name from every $something from our function, right ? So I can name it $whatever if it only follow function syntax, right or not ? If yes, why when I change name it show error ? Or maybe it shows error because MINFILTER is function not name you think up from nowhere, so it has to be named like this ? But it shows error even if I change x to something else. Or maybe I make error somewhere in my thinking ? Thanks Edited April 2, 2008 by SWANN Quote Link to comment Share on other sites More sharing options...
Andz Posted April 3, 2008 Author Share Posted April 3, 2008 SWANN said: Could you explain this funtion:$dangle = max(abs(Du($x))+abs(Dv($x)), $MINFILTER); Hi Swann, I guess Sybarrick will have to help you on that one. As I mentioned on my post, that outline code I got from him LINK. All I did was the cross hatching. Quote Link to comment Share on other sites More sharing options...
Guest Swann Posted April 3, 2008 Share Posted April 3, 2008 Thanks Quote Link to comment Share on other sites More sharing options...
cellchuk Posted April 3, 2008 Share Posted April 3, 2008 cool shader :thumbsup: Quote Link to comment Share on other sites More sharing options...
