Killswitch Posted May 12, 2021 Share Posted May 12, 2021 I'm trying use seed attribute which is exported from pointvop to primitivewrangle and create cluster for my destruction please check the bellow file please help me out. cluster.hipnc Quote Link to comment Share on other sites More sharing options...
underscoreus Posted May 13, 2021 Share Posted May 13, 2021 Heyo! Not in front of a machine with Houdini right now so can't test your scene file but I did notice from your images that it seems you've misspelled "@primnum" as "@prinum", maybe this could be the cause of your issues? A good way to debug your vex code is to "print" the result of your operations, like getting attribute values from specific points etc, to a test attribute to see what the result is. That way you can quickly see if a function is not giving you the result you were expecting. Quote Link to comment Share on other sites More sharing options...
Ultraman Posted May 14, 2021 Share Posted May 14, 2021 (edited) On 5/12/2021 at 5:05 PM, Killswitch said: I'm trying use seed attribute which is exported from pointvop to primitivewrangle and create cluster for my destruction please check the bellow file please help me out. cluster.hipncFetching info... Expand Hi ... look hip file. I use different way , maybe help u cluster.hipncFetching info... Edited May 14, 2021 by Ultraman Quote Link to comment Share on other sites More sharing options...
Killswitch Posted May 14, 2021 Author Share Posted May 14, 2021 @underscoreus Ya, man I didn't notice it and it's working now Thanks' man thanks a lot! @Ultraman The way you solved this problem is really good thanks bro thanks for the help. Quote Link to comment Share on other sites More sharing options...
