Abstract Spline in houdini?
RTF
I'm a new houdini user from c4d and I want to make this effect MS-Y_MASTER_Lossless-00219.jpg , the animation like
 07s-09s
and I do this learn from
, but the animation is not very well.
So can some one help me or give me some tutorial to do this effect
thank you very much
Vellum runs , it's just you made some mistakes ;)
In your vellumhair setup constrain pin i snot set to your pin group .
Then you have to polypath to get only one prim.
More importantly , the pin change from frame to frame as the sop solver in your popnet add new points every frame...
Ok, finally if you drive your contain using the actual transform, you will probably not get close to your reference , play with the scale as well , or maybe restlengh
Hope it helps!
________________________________________________________________
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
 http://fr.linkedin.com/in/vincentthomas
  • 1 month later...
For some reasons, I haven’t logged into the forum for a while, thank you for your answer.
And I try to use polypath but Still no work.
I think if it can Divided into two parts, first is Emitted particles connected into a line and secondly is vellum sim.
But I can't put dop into the vellum.
Could someone help me.
Thank you very much
