cloudamy Posted July 20, 2021 Share Posted July 20, 2021 Hi, I want to control the movements of the particles on the surface by some velocity that I specified myself. I have looked up some posts here and I have tried to implement the particles along surface effect using pop network. However, it is not working as I want. I don't understand why my vex code over here is causing the surface to move too, I want the particles to move along the x-direction but only on the original geometry position, is this not the right way to do it? Quote Link to comment Share on other sites More sharing options...
tamagochy Posted July 21, 2021 Share Posted July 21, 2021 You can do it like this. pop_moveGeo.hipnc Quote Link to comment Share on other sites More sharing options...
vinyvince Posted July 23, 2021 Share Posted July 23, 2021 That should work, try something like this instead and be sure to ever creat a wrangle with vel pointing to x only and define this in the source input. One interesting this is when using the minpos() and grain, some particules here like you could see in my stupid test are sticked to the left, struggle to find their way. only when usin grain but they follow correctly the terrains, stop . Then using attribute interpolate, previous setup same scenario but you get that second picture now... ________________________________________________________________ Vincent Thomas (VFX and Art since 1998) Senior Env and Lighting artist & Houdini generalist & Creative Concepts http://fr.linkedin.com/in/vincentthomas Quote Link to comment Share on other sites More sharing options...
